Guest NickTaylor Posted February 17, 2003 Report Posted February 17, 2003 I have now tried to use my desk with the above scanners. There is some control, but not consistant across the units. I cannot get the colour to work at all. The start addresses are dmx 80,88,96 and 104 . The fact I cannot get colour at all would seem to indicate there is no signal for that parameter. Any ideas out there? Nick Quote
Guest Nicktaylor Posted February 18, 2003 Report Posted February 18, 2003 It seems that Zero 88 were given the incorrect controls for the fixture library for my scanners. Zero 88 support suggested using the Coemar Mini Ultrascan library and this appears to have worked! In case anyopne else is stuck with these in the future the contols appear to be 1 Pan 2 Tilt 3 Blank 4 On / Strobe 5 Gobo Shape 6 Rotate Gobo. 7 Colour 8 Half Colours. ( Not sure if this is supposed to happen but does!) Intstalling Coemar Mini Ultrascan 2 seems to do the trick. Quote
