i have just got a Jem ZR-12-DMX
it is possible to control this by DMX aparently, how do i do this? it is controlled by 1 channel so i should be able to control it with a sub??
how do i assign it up and everything??
cheers
Dom Gross
The easiest way would be to patch one of the generic channels to the DMX address of the Jem ZR12 smoke machine.
You can then use the appropriate preset fader to control the Jem directly as you would a dimmer channel, or you could set the preset fader to full, ensure that all other generic channels (preset faders) and fixture brightness channels are at zero and record this directly onto a submaster.
You could then use this submaster as the Jem control
