yellaasian Posted February 9, 2003 Report Posted February 9, 2003 Hay The Club I Work for just bought a Leap Frog recently And 4 of the bump buttons do not work and there is also a glitch that make everything strobe..... We are going to call the distributer Monday to get another one sent to us, I think it might be just loose parts inside but I thought id put a bug in your ear just in case. We had the fat frog and loved it trying to find a new and lovig home for it... Thanks BOB Quote
Paul Posted February 25, 2004 Report Posted February 25, 2004 If you just bought it, send it back to your distributor and they should repair/replace it for you. However if you're feeling adventurous, remove the front panel assembly from the base assembly (only 2 screws) and check all the ribbon cables are securely seated. This would be the most likely cause of the problem you describe. Quote
