I've finally bought a mambo and used it this weekend for the first time.
Now, how kan i program a memory-chase (position ) without programming brightness, color and beamshape?
Den Pipo
Pro Light Design
If you wish to program a memory down to attribute level:
Ensure that the Program Mode is set to Partial in Desk Setup.
Check that only the fixtures to be recorded are tagged (yellow LED in fixture selection button is flashing)
To record a single attribute (eg Position), press and hold down the attribute button and then press the Program button.
Note - Generic and fixture brightness channels are always recorded regardless of which fixtures are tagged and which attribute buttons are held prior to pressing program.
If you don't wish the brightness levels to be recorded, ensure that that they are at zero when you press Program.
See Mambo Frog Operating Manual (Issue 2) pages 3-4, 3-8 for details.
