Guest Johannes Posted January 12, 2003 Report Posted January 12, 2003 Hi, The Frog seems to be the right console for our needs (small theatre). The only thing I'm not sure is: is there a way (apart from using the submasters) to crossfade manually from one stack-Memory to the next (same as pressing the GO-Button, but with a Fader?). If not: will there be such a Feature in a future release ? Thanks Johannes Quote
K-Nine Posted January 13, 2003 Report Posted January 13, 2003 There is not currently a feature as you describe, although the 'Go' button crossfade can be manually overridden, allowing you to speed up and slow down the crossfade. As to whether it is a feature that will be in a future update, I can't say either way... We will include it in the suggestions database, and it will be reviewed. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
