Guest janvh Posted January 2, 2003 Report Posted January 2, 2003 Hi I use a strobe of JB systems Light FL1800DMX I whant to use a submaster to assignthe dmx value of my strobe. is it possible to stick a Variable DMX value (0%-100%) on a submaster. i can use the submaster only for triggering a movement or to trigger a memory. can some one give me an answer Friendly regards Jan VH Quote
Paul Posted January 3, 2003 Report Posted January 3, 2003 I think the strobe you refer to has 2 DMX control channels - one for rate, and one for intensity. I'm assuming you have a desk which can handle LTPs - Fat Frog, Leap Frog, Bull Frog or Mambo Frog. If you have created a fixture personality for this strobe which assigns the intensity control channel be HTP (Highest Takes Precedance), then the rate control channel must be LTP (Last Takes Precedance), as each fixture is only permitted to have 1 HTP channel. The submaster fader varies only the HTP output channels. The LTP output channels are triggered to their programmed values when the submaster fader crosses the programmed LTP trigger level. If you want the submaster fader to vary the rate of your strobe, then in your fixture personality you will have to assign the rate to be HTP control. If you also want the intensity to be HTP control, then you will have to control the strobe as 2 fixtures. Alternatively, and this will work on a Frog (which doesn't have LTPs) too, use 2 of the generic control channels to control your strobe. Quote
Kashirkin Posted December 28, 2003 Report Posted December 28, 2003 Dear sirs, Does anybody knows how to assign at least one more HTP channel to a fixture in addition to a "brightness" attrribute? We've installed a mixed (dimmers+moving) lighting system for night venue with 10 moving spots under BullFrog control. Some invited light designers ask me to explain how they can assign a common for all fixtures attribute to a submaster with a propotional to a fader movement changing, e.g. gobo rotation speed or amount of "cyan" or "magenta" for CMY wash fixture. Our trials to assign a HTP status for choosed fixture control channel followed to nothing - I've understood that only 1 HTP channel for each fixture is allowed - the "brightness", all other channels have always LTP status. Could you help me with this problem? Thank you in advance. Quote
ice Posted December 29, 2003 Report Posted December 29, 2003 This simply can't be done. It's impossible to program only C/M/Y values or gobo's etc. onto a submaster since you can't program on attribute level. There are some more topics here about transparant programming, you should read them to understand what the desk can / can't do. Quote > 500 posts, time for a new T-shirt?
K-Nine Posted January 5, 2004 Report Posted January 5, 2004 At present, a fixture can only have a single "Brightness" parameter. In the future, we may look at changing this limitation, but this impacts significantly on the processor loading of the desks, due to the HTP nature of the mixing. Allowing more than one "Brightness" parameter will require changes in both the desk software and the fixture editing utilities which are used to produce the fixture personality files. Frog Reference 5411 - Allow more than one HTP parameter to be defined in Brightness for a fixture. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
_chris_ Posted February 4, 2005 Report Posted February 4, 2005 Is it possible to set one specific control and assign it to a fader, for example to have movement on a fixture using the wheels, but at the same time having dimmer and colour controls using the faders for channels 1-2 on a fat frog? Quote
Paul Posted February 4, 2005 Report Posted February 4, 2005 Not possible on the frog series, sorry. However this is something you can do with the user definable faders on a Frog2. Quote
_chris_ Posted February 4, 2005 Report Posted February 4, 2005 Is it possible to assign the colour channel to a submaster channel? Quote
Gabzqc Posted February 16, 2005 Report Posted February 16, 2005 but surely if one was to program a memory of a fixture changing to , say blue, then move that over to a submaster, in the bank of 12 on the bottom of a fat frog, then you would be able to change colours? please correct me if i am stupidly wrong... cheers Quote
K-Nine Posted February 16, 2005 Report Posted February 16, 2005 You could program the state/scene you require (for example, fixtures 1-4 go to blue) either directly to the submaster or by programming a memory and transferring it to the submaster. Raising the submaster will result in the fixtures going blue when the fader passes the LTP trigger level. The submaster fader will only control the brightness parameter of the fixtures (HTP), but the colour parameter(s) will be triggered once on passing the trigger level (LTP action). You cannot assign a single colour, or any other LTP channel to a submaster fader - the submaster faders only control the generic and fixture brightness channel levels (HTP) and trigger the LTP data. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
GLX Posted February 16, 2005 Report Posted February 16, 2005 You should use the pallets for changing colours live. Hopfully K-Nine will push for the fade in/out times on the pallets so you have the choice to fade or snap your colours or gobos. Would work great with the wash fixtures. Quote
gress Posted April 15, 2005 Report Posted April 15, 2005 I would like to be able to just change one channel for my Martins and have that on a submaster. Here is what I would like I have a submaster for my Martins pulled up for a GOBO, COLOUR and POSITION. Then I would like to be able to just adjust/jump one channel for a strobe speed or something like that without changing any other attribute. Is this possible? Right now I use the wheels and it can be pretty touchy trying to go to what you want quickly. Quote
ice Posted April 15, 2005 Report Posted April 15, 2005 Nope that can't be done. Programming individual parameters is not possible on current Frog series. Frog 2 can do this though! Quote > 500 posts, time for a new T-shirt?
Paul Posted April 16, 2005 Report Posted April 16, 2005 I think there's possibly 2 issues here... Firstly, you can't currently program down to parameter level (do a search for Frog Reference 5402 to see the many discussions on this). Secondly, you can't control the level of an LTP channel with a submaster fader. Quote
BluesHarpVienna Posted October 11, 2005 Report Posted October 11, 2005 Hi there ! Is it possible to control the DMX-channels of the movinghead NOT via the wheels but with the submaster-faders? Thanks in advance for your help, "busy" Tom Quote
nickwoolley Posted October 11, 2005 Report Posted October 11, 2005 Hi, Why do you want to do that, we can then help with your situation. HTH Nick Quote What if...
Paul Posted October 11, 2005 Report Posted October 11, 2005 In short, I think the answer to your question is no. The position of the submaster fader determines the output level of the HTP channels (dimmer channels and fixture brightness parameters) programmed in the submaster. LTP channels (fixture colour, beamshape and position parameters) programmed in the submaster are triggered when the submaster is raised past the LTP trigger level. Quote
Pipo Posted October 17, 2005 Report Posted October 17, 2005 This can be done! Just patch all the parameters as a dimmer-channel. Have fun Quote Den Pipo Pro Light Design
Queerdoo Posted December 28, 2005 Report Posted December 28, 2005 I have a couple of Robe Color Wash 250AT, and i want to have each of C,M,Y values on subs so i can do live colour changes without colour pallettes... Is that possible? With our old NSI MC 24/48 it works fine to do that. Quote
Paul Posted January 4, 2006 Report Posted January 4, 2006 No, you cannot control LTP parameters using the submaster faders. Quote
Tim Olson Posted January 15, 2006 Report Posted January 15, 2006 what do you mean? I have been getting ltp parameters out of my subs....there's an ltp trigger level..... do you mean it's impossible to record just one parameter on a sub? didn't I just read that there's a way to output just the color, or beam, or position info to a memory? peace, Tim Olson AV Concepts Quote
Kirkup_xp Posted January 15, 2006 Report Posted January 15, 2006 What Paul means is that you cannot use a submaster to control the level of an LTP parameter. You can record a single level into the submaster (assuming you have version 10 software) and use the sub to trigger that LTP level, but you can't use the sub to set the level. Does that make sense? Quote Peter Kirkup
Tim Olson Posted January 17, 2006 Report Posted January 17, 2006 so in other words, I can record one parameter in a memory, and set the sub to play back just that parameter, but the only option I have is to play it with the timing in the memory or with no timing at all. I thought I read that if you put no timing in the memory, the sub would execute manually. apparently this is only for HTP levels. This means you can get either a faded or a snap exectution of the parameter - yes? I'm still in the dark about how to tag just one parameter peace, Tim Quote
Paul Posted January 17, 2006 Report Posted January 17, 2006 From version 9 software onwards, the fade times on submasters can be programmed to whatever you like, regardless of whether the sub contains a transferred memory or channel data. For LTP parameters, it is the 'LTP Fade Time' that you need to adjust. You also need to make sure the action for the appropriate attribute (colour/beamshape/position) is set to 'Fade'. When the submaster fader is raised above the 'LTP Trigger Level', the fade is started. Full details of tagging individual parameters are given in the Software Release Notes for version 10 software. Quote
