eutaysj Posted December 30, 2003 Report Posted December 30, 2003 hi i am new to the board. am required to operate the 120 in a theatre. am curious whether isithere anyway where this board can operate moving lights. Quote
richard Posted January 6, 2004 Report Posted January 6, 2004 You could operate a limited number of moving lights on the desk, but it isn't pretty! You would have to treat each attribute of the lamps as a different channel on the desk - ie channel 1 would be pan, 2 tilt, 3 colour etc (depending on how you set it up). You could then put the pan and titlt on to subs to help but it would be quite messy.. Quote
K-Nine Posted January 7, 2004 Report Posted January 7, 2004 Richard is quite right, you can run moving lights on an Illusion 120/240 on a channel by channel basis, but the interface is not really designed for moving light contol ..... however the the Illusion 500 with the new moving light software certainly is :wink: Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
m1ndy9876 Posted July 18, 2007 Report Posted July 18, 2007 Morning all ( bringing a OLD thread back to life) Just to check, if I set for example a Mac250 to channel 50 (taking up 12 channels (or what ever it is)) and then programmed submasters 1-12 1 being channel 50 and 12 being channel 62, would this work to control a mover? Like wise with this could I then take the setting from this page SAVE as a submaster on another page and run that? Thanks Tom Quote
