Submaster
Guest Jean2002
Hi,
I have a Mambo Frog, i've got a problem, i have programmed a chase movement on my submaster, can i choose my colors en gobos before i open the slide of the submaster, and can i hold my colors And gobos when i change the other submaster to an othe r movement.
(sorry my english is not so very good)
i hope some one can help me
greetz
If you set the LTP trigger level for the submaster to be a low value (eg 5%) then the LTP channels in the channel data or transferred memory will trigger as soon as the submaster reaches that value.
If you wish to keep the same colours and gobos set by one submaster, then output another submaster which changes position but does not affect the colours and gobos of the fixtures then you need to program that submaster with position data only.
Partial programming down to attribute (colour, beamshape, position) level was introduced in Version 7 software.
The software and accompanying release notes describing how partial programming works can be found on the Zero 88 website.
Bran Media | Myspace
