The "fade up" time of a memory is the fade time for channels which are brighter in the incoming memory than they were in the outgoing memory.
The "fade down" time of a memory is the fade time for channels which are dimmer in the incoming memory than they were in the outgoing memory.
The "dwell time" is only relevant when the next memory has the trigger set to Auto. It is the time for which the memory is output (after completion of the fade up and fade down into the memory) before the fade into the next memory is triggered.
