yellaasian Posted November 26, 2002 Report Posted November 26, 2002 when i set the (other speed) on my 918 roboscans beanshape wheel group to slow down my color scroll it affected the the blackout speed on the fixtures. the blackout button should blackout everything instantaneously and override the effect speeds correct ??? thanks Bob Quote
K-Nine Posted November 26, 2002 Report Posted November 26, 2002 I don't know exactly how the 'other speed' parameter on the Roboscan fixture works, but you mention it in terms of a beamshape parameter. The Blackout button on the Frog desks only affects the HTP or brightness channels. Therefore, only the fixture parameter which is defined as the 'Brightness' parameter will be reduced to zero when you press the Blackout button. This should happen immediately - I would suggest that you check on the Outputs screen for verification. If the fixture itself does not blackout straight away, then this may be a result of the value of this 'other speed' parameter. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
