Anyway of utilising one of the faders to be a flash master? I find it particularly annoying that there is no control over brightness for channel/submaster flashes.
Cheers Si
backSTAGE Theatre Supplies LTD
Specialists in
Lighting / Staging / Consultancy
I would set the Grand Master to the desired output level and then flash or soloing any channels or subs you want.
Anyone a better idea?
So, if you don't start drinking...I'm gonna leave!!!
Grand master would affect all outputs. EG, you had a chase running on a sub and wanted to flash a particular channel. Grand Master wont help you.
Specialists in
All I can suggest is having a separate page of subs with your programmed flashes on, so just flick over to this page and do your flashing. Certainly not ideal though :)
sp
