lxkev Posted June 12, 2005 Report Posted June 12, 2005 Been looking through the manual and have found little on the midi side of things. I was wondering when midi is gona be done on the desk, and if i can ask for a feature which will be of great use to me, and im sure for some others who are getting into show control. Il explain my set up. digital sound desk (states can be called up by midi commands), PC running emagic logic (markers play audio and video). What i want to be able to do on the frog 2, is to use the go buttons to trigger midi i.e. when a cue is outputed. it sends out midi program change commands. Any chance of this happing? could really do with it by mid summer. Looking at the Pearl, when you shove midi into the desk it allows notes to control playbacks. Sine the frog 2 playback is advanced then the pearl, could this happen..... Assign midi channel to a stack, and then every time a note is received i.e. a c. it triggers the cue. Or assign a midi note to a cue. Time code great, but in a life situation it not the best, and the midi note/commands come a massive help. Thanks Quote I need a new job
K-Nine Posted June 15, 2005 Report Posted June 15, 2005 At present we have only used MIDI timecode signals to trigger cues with MIDI timecode triggers. In future releases of software we will be looking at MIDI Show control and MIDI notes response. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
