Sign in to follow this
LTN Productions
reset desk
Can someone tell us how to reset the desk. By this i mean the whole desk, fixtures, patch, pallete etc but retain desk fade times, without doing them one at a time?
Is this possible? if not can i suggest it. Clearing them individually is a bit of a pain.
Clear to Default will clear all the memories, submasters, SX buttons, palettes and groups on the desk. It will also reset all the Desk Setup parameters to their default values.
If you want to clear all the memories, submasters, SX buttons, palettes and groups but retain the desk setup data, which includes the default fade times then use Clear All.
The Desk Setup Data contains the following information ...
Desk Defaults (memory and submaster fade times, actions, triggers etc.)
Fixture assignments, pan/tilt options, and DMX patch
Program Mode
Remote Switch Setup
Frog Screen Setup
Timecode Setup
A Clear All will NOT affect any of this desk setup data
A Clear to Default will clear all the desk setup data and return all values to desk defaults.
Hope that makes things clearer.
if you own the board and you do lots of shows what you should do is just when you are done setting your base settings save it to disk like it was a show and use it as a base settings disk this is what most rental houses do for there rental consoles
JH
