Gabzqc Posted June 4, 2005 Report Posted June 4, 2005 well what happened was someone knocked the monitor, and for some reason this triggered something weird on the desk, when one changes the function, for instance, the submasters or memories or preview, outputs the led's in them flash, as if its in test mode..., then pressing the submaster flash buttons does the same, press it it starts flashing, and press it again and it stops flashing. could it have been the knock, or is there something i'm missing... thankyou Gab Quote
sp Posted June 4, 2005 Report Posted June 4, 2005 The only thing I can think of is if the F3 button was pressed on either the desk or the external keyboard. This could put the desk into 'Live individual Chase adjustment mode' whereby you can select individual chases and adjust their parameters live. If you pressed F3 and were to then press the Submaster or Memories button, as you describe, I think they would flash, as would the submaster flash buttons. So basically, all I can think of is that F3 was pressed sp Quote
Gabzqc Posted June 6, 2005 Author Report Posted June 6, 2005 brill ok cheers for your help im sure it must have been that, ok no worries! thanks again gab Quote
