dooza Posted May 15, 2005 Report Posted May 15, 2005 Hi there, I am thinking about getting a Diablo. I like the features, but would like someone to clarify something for me about the Global Chase. In the manual it states the following: The current state of all 12 pages and page ripplesThe current sequence page The sequence speed, direction and sound on/off settings Does this remember the actual sequences that are running? Does it remember the step of a manual sequence? What would be great is if it also remembered any selected memories, especially those with effects running on them. Just like an envirnoment on a Masterpiece. I cant find any downloadable fixtures on the website. In particular I am after any Abstract lights, and the Martin 812. Any help would be great. Cheers, Steve www.dooza.tv Quote
Paul Posted May 15, 2005 Report Posted May 15, 2005 The Diablo has 12 sequences, 1 per page. Since the Global Chase Control feature stores the current sequence page, then yes it is effectively remembering the current sequence. Note only 1 sequence can be playing at a time, however the page chase / page ripple features can be used to very easily change the look of this. The Global Chase Control feature does not however store the current step of the sequence or any submasters which are raised. The Diablo Fixture Manager software (included on a CD with the desk, or downloadable from the Zero88 website) uses the same fixture library as the Frog and Illusion desks. Simply select up to 18 fixtures from that library, connect your PC to the desk with the USB cable provided, and transfer them. Quote
dooza Posted May 15, 2005 Author Report Posted May 15, 2005 Hi Paul, Note only 1 sequence can be playing at a time, however the page chase / page ripple features can be used to very easily change the look of this. I thought the manual implied that you can have more than one sequence running at a time, but looking back it doesn't. I will have to stick to page chases if I want to layer chases. The Global Chase Control feature does not however store the current step of the sequence or any submasters which are raised. Thats a shame, could I make a feature request so that it does? The Diablo Fixture Manager software (included on a CD with the desk, or downloadable from the Zero88 website) uses the same fixture library as the Frog and Illusion desks. Simply select up to 18 fixtures from that library, connect your PC to the desk with the USB cable provided, and transfer them. Excellent, I will search the library for the ones I need. Thanks for the help. Steve www.dooza.tv Quote
sparky_stephen Posted October 26, 2005 Report Posted October 26, 2005 Hi, Is it possible for the Diablo to power-up into the Global screen? I have one installed in a nightclub and it would be much simpler for them if it would go straight into it. cheers, Quote
Paul Posted October 26, 2005 Report Posted October 26, 2005 It's not currently possible to do this on the Diablo I'm afraid. Sorry Quote
sparky_stephen Posted October 26, 2005 Report Posted October 26, 2005 How does one request that it make it into the next software release? Quote
Paul Posted October 26, 2005 Report Posted October 26, 2005 Hi Stephen, Unfortunately the Diablo has no facility to perform software upgrades in the field, it would need to be returned to the factory to be upgraded. Even despite the potential deployment issues, there are no immediate plans for any Diablo software releases. I have however made a note of your idea, just in case it ever comes about in the future. Thanks for the feedback, Paul. Quote
