Koemar Posted May 10, 2005 Report Posted May 10, 2005 Hello, I was programming the frogbox+frog screen, and everything goes well, but when i want to start up/rename some memories with the frogscreen it goes wrong. I can select the memories on the frogbox, AND i can see them (and start them) on the crt-monitor, which is connected on the frogbox..... BUT i can't see them on the frogscreen! I gave the chases a name on the fat frog, and saved it as a show. what's wrong? Greetz Ronnie Quote
Koemar Posted May 10, 2005 Author Report Posted May 10, 2005 I've a question: The manual says that the + and - button of the frogscreen works the same as the one on the frogbox. But when I enter the 'superuser mode' on the frogscreen my frogbox doesn't enter the superuser mode, and the + and - buttons aren't the remote buttons of the frogbox..... How can I solve that problem? Greetz Ronnie Quote
Paul Posted May 10, 2005 Report Posted May 10, 2005 Is there any evidence that the Frog Screen is communicating with the Frog Box at all? This could be a cabling issue (check connections, terminations, power etc.). Is the CAN Mode set to 'Chillinet' on the Frog Box? Quote
Koemar Posted May 11, 2005 Author Report Posted May 11, 2005 Thanx!! The Can mode was disabled 8) Greetz Ronnie Quote
