Im sorry to keep buggin you all !
you see im 14 and i work in my school theatre i really need these lights to work proppa ! Mojo Scan 1 + 2
if anybody is kind 'a' nuf to recreate these drivers to put the shutter on the dimmer button, i would be so so so grateful !
thankyou!
Hi dmxeater,
your mojoscans didn´t have a shutter they only have
PAN / TILT / COLOUR / GOBO
now when you put the Gobo option on the brightness button you cant create gobo presets with your bullfrog.
Its a matter of coherent programming to get this thing to work.
Don´t hesitate to PM when you have any problems with your Mojos
to get fixture files of mojoscan 1 + 2 where beamshape option is switched to brightness CLICK HERE
Sebastian H.
Pro - Sound Showtechnik
Albert Einstein
Al Capone
But they do have a shutter, its on the gobo wheel
The mojo scan 1 has only 1 wheel - coloured gobos
The mojo scan 2 has 2 wheels on it - colour and gobos
is the driver for both different fixtures ?
Also, how do i download the driver? im usuing a mac ! It comes up as a text file!
How do i convert it ?
Sorry lots of Q's !
thanks for the help tho !
I think Haytech is saying it doesn't have a shutter channel. A single channel of the mojos controls both the gobo and 'shutter' - it is not possible to put just the gobo section on the fixture's beamshape, and the 'shutter' section on the dimmer wheel - as far as I know :)
sp
I upload the file as a StuffIt Arcive can be found HERE
The file include drivers for mojo scan1 + scan2.
Extract the files directly to desk formatted disk.
To bring light into the darkness :D
The mojo´s didn´t have a shutter or dimming device - it has a gobo wheel where the position "closed" and "open" can be indexed.
To see how your fixtures work really you can use the generic part of your desk - give your mojoscan2 DMX address 1 so you can see what happening on direct controlling the first 4 faders : 1:gobo/shutter 2:color 3:pan 4:tilt
now you can check which DMX values are for closed/open/gobo 1/gobo 2 ...
regards
Sebastian H.
Albert Einstein
Al Capone
Ok, What i think im gonna do is put the values of the shutter on to a sub so that when I get to the end of a scene, i wil just hit the sub.
Thankyou for the help
i think im sorted !
stu
You can also put it into a preset -
select your scan - push beamshapebutton and a generic channel flashbutton at the same time - the values of your beamshape will be stored to this "preset" button.
presets can be used in submaster and in memeory stack though it is possible to change every "open" scene into a "gobo".
To save the beamshape option only - press beamshape and program at the same time when programming your submaster. This saves only the beamshape options to the sub.
regards
Sebastian H.
Albert Einstein
Al Capone
