ice Posted April 27, 2005 Report Posted April 27, 2005 Exactly how accurate is the memory timing on Frog consoles? I've programmed a show to music and used some fade times of zero or close to zero (0.1, 0.2). I noticed these times aren't too accurate. For instance a fade time of 0.0 on memory 1 with an auto trigger to memory 2 should immediately go to 2 right? Since theres no fade time and no dwell. Instead of going there at once it needs some calculation time I think, and then it goes to the next memory. Okay, I understand I'm pushing the limits here, but I just wanted to point out a really well timed show is almost impossible when you've got to deal with these problems I've made some work-arounds with manual GO presses, now it works just fine. Quote > 500 posts, time for a new T-shirt?
K-Nine Posted April 27, 2005 Report Posted April 27, 2005 Another thing to bear in mind is that even if the DMX outputs of the desk snap to the new values in zero time (or as close to zero as possible) not all fixtures can respond that quickly, especially if it involves large movements etc 8O Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
ice Posted April 27, 2005 Author Report Posted April 27, 2005 I know, but I've got some Palco's here: extremely fast led fixtures, and only use intensity / colour channels.. those are fast enough to keep up. Quote > 500 posts, time for a new T-shirt?
Paul Posted April 27, 2005 Report Posted April 27, 2005 The desk loop (and DMX refresh) time is approx 35ms (0.035s). This is the finite timing resolution of the desk. If you're trying to use times anywhere near this resolution, you're going to run into problems. Even if the desk could go at the theoretical maximum DMX rate of 22.7ms, what you're trying to achieve would still be nigh on impossible. Quote
ice Posted April 27, 2005 Author Report Posted April 27, 2005 Okay, but fade times of 0.1 also don't seem to be 100% accurate, while that can't be a dmx problem right? Oh well, I solved it anyway, so it's not that big of a deal. Quote > 500 posts, time for a new T-shirt?
