jontip Posted April 11, 2005 Report Posted April 11, 2005 How do I assign a hazer using 2 DMX Channels? Do I need a fixture library definition for this?
Martin Posted April 11, 2005 Report Posted April 11, 2005 if you dont use all 48 generic channels you can just set it up at them, ee.g chan 47+48 Move while dark! -> GOGOGO! Thank you Zero for the FR 5402
Haytech Posted April 11, 2005 Report Posted April 11, 2005 You can also create your own fixture file with the Fixture Type Editor found HERE Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
ice Posted April 11, 2005 Report Posted April 11, 2005 Creating a fixture is better for a hazer, you can assign it to two colour or beamshape parameters and that way it'll always output fog. When you place it under generic channels this might give you some problems with fades etc. I always use a 2 channel scroller fixture for our hazer, works fine! Just don't record it into any scenes and manually set the output with the wheels. > 500 posts, time for a new T-shirt?
KWR88 Posted April 14, 2005 Report Posted April 14, 2005 CLICK HERE to download the file. NB: files may be removed from here once they are added to the main fixture library. Regards, Keith Rogers Zero 88 Support: support@zero88.com
