ice Posted April 5, 2005 Report Share Posted April 5, 2005 For an upcoming show I need an effect in my heads. There's a break in the show in which everything has to be pauzed, as if the stage is frozen. I want to program a move with my heads and also a rotation gobo. When the show is pauzed the move and gobo rotation have to be stopped. I want to do this in the memory stack if that's possible... anyone got some brilliant ideas on this? Quote > 500 posts, time for a new T-shirt? Link to comment Share on other sites More sharing options...
Kirkup_xp Posted April 5, 2005 Report Share Posted April 5, 2005 Does the pause happen at the same time every night? If so, its simple - three cues - Cue 1 - Move w/rotating gobo (Beam=Snap, Position=Fade) Cue 2 - Stopped w/static gobo (Beam=Snap, Position=Snap) Cue 3 - Move w/rotating gobo (Beam=Snap, Position=Fade) If you need the pause to happen erratically, what i'd suggest is to do it with a crossfading cue, plus two subs: Cue 1 - Position 1 (previous cue) Cue 2 - Fade to position 2, rotating gobo (Beam=Snap, Position=Fade) Sub 1 - Gobo static (Beam=Snap) Sub 2 - Gobo rotating (Beam=Snap) At the relevant point, pause playback X, and at the same time, hit the sub 1 flash button. When you want it to restart, hit sub2 and unpause the cue. Voila. Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
