combine fixure, in submemories/masters FATFROG
hi is it possible..
i have 3 different scans
i wanne program them en put it in the submemories faders.
my problem, sub 1 is fixure 1-4, and sub6 is 5-8
i wanne show both and not one of them
i wanne use more subs at the time..
helpp
Yes it is possible to do this.
You must first put the desk into partial program mode. You need to do this before programming or it will not work
This can be found in Super User/Desk SetUp/ Desk Defaults/ Program Mode.
What will happen then is only the fixtures that you select and then "tag" by adjusting the parameters will be recorded when you press the program button. This then lets you run different fixtures on different subs as well as generic stuff as well.
Keith Rogers
Keith was close :wink:
It is actually an option under Desk Setup in Super User.
See The Frog Series Operating Manual pages 6-2 and 6-9 for details.
