amillar Posted March 17, 2005 Report Posted March 17, 2005 Hi, what is the minimum size of external monitor (probably TFT) that you folks you recommend for using with a Fat Frog desk? Thanks, Andrew. Quote
AcmeMike Posted March 17, 2005 Report Posted March 17, 2005 yeah, i use a 17 inch lcd monitor. i find it is more than plenty for the fat frog. you could easily get away with like a 14 inch. i have it hooked up to a k/v/m switch so i can use the same monitor and keboard for both my booth computer and my fat frog. i also have all my video gear going through the computer so i can use the same monitor to preview/cue tapes and dvds and check camera feeds. thats the only reason i needed the larger screen. Quote
K-Nine Posted March 17, 2005 Report Posted March 17, 2005 The monitor display is text only with a resolution of 80 characters by 50 lines high, so I guess it really depends on where your monitor is located (ie how far awayfrom you and the desk) and how good your eyesight is Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
gress Posted March 28, 2005 Report Posted March 28, 2005 I use a 15" LCD monitor (oder HP model) for our bullfrog - works great Quote
