hi there, i have just received a shinny new beta pack. we have put a 13amp plug on, using a 15amp cable. it is all connected up right!!
i then went to test on some parcans, i put one on channel 6, pressed the test button and it worked, i then tested a socket with nothing in it?!?!
it hasnt worked since.
we have tested all conections and fuse in beta and plug are fine? when you unscrew the fuses on the front, the red light appears, so there is no fault with power from the plug? is there any thing you recomend trying,
thank you
Dear Sir,
I think that I have already spoken to you and we have arrange to have the pack returned.
If not please pm me for return details.
Keith Rogers
