PatrickK Posted January 20, 2005 Report Share Posted January 20, 2005 Hi all, Tonight we bought a secondhand fatfrog, so I'm finally in the club I've checked the desk and everything is in perfect order, except a faulty yellow led on fixture button 6. Booted the desk in testmode and every other led works fine, including the red one in the same button. The yellow led just doesn't light at all. Led's don't burn out, so must be something else. So before I break out the screwdrivers, does anyone have a suggestion what to check? Quote Link to comment Share on other sites More sharing options...
Gabzqc Posted January 20, 2005 Report Share Posted January 20, 2005 wow, how do you boot the frogs up in test mode...? //gabz Quote Link to comment Share on other sites More sharing options...
PatrickK Posted January 21, 2005 Author Report Share Posted January 21, 2005 Hold the F1 button during powerup. You can then use the channelflash buttons to select the different testpages. With the submaster-step button you can toggle all leds on/off Quote Link to comment Share on other sites More sharing options...
KWR88 Posted January 21, 2005 Report Share Posted January 21, 2005 You may find that it is just the LED that has failed. There are a couple of reasons that they can go. It would be worth dropping the fixture PCB out to check the for signs of liquid spillage etc. The only thing is that it is easier to replace the button than try and change the LED as getting the button apart with out damaging it is a nightmare. If you want to PM your address to me on krogers@zero88.com I will send you a button. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
PatrickK Posted January 21, 2005 Author Report Share Posted January 21, 2005 Alright Keith, thanks already. 8) I'll check the board first thing tonight and let you know. Update: issue has been resolved. After examination of the fixture pcb it turned out that some excess solder made a short between both pins of the led. After cleanup all the leds are now functioning. Quote Link to comment Share on other sites More sharing options...
