ice Posted January 19, 2005 Report Share Posted January 19, 2005 Found a small bug: [*]create about 10 different chases (I don't know if scene's will produce the same effect) [*]copy the first chase to submaster 1-1 [*]copy the second one to submaster 2-1 [*]repeat these steps a few times and you'll notice the memories screen crashes; you can't go up or down anylonger! It's easily solved by pressing the submasters button and memory button again, but I thought this should be mentioned here. I found the problem: first press tranfer no time, and then raise the submaster page; the memories screen will crash Quote > 500 posts, time for a new T-shirt? Link to comment Share on other sites More sharing options...
K-Nine Posted January 25, 2005 Report Share Posted January 25, 2005 I found the problem: first press tranfer no time, and then raise the submaster page; the memories screen will crash I have just tried this on the Phantom Frog and it does the same with the transfer with time; if you page up or down then transfer the memory to the submaster - the memories screen locks up - press Submasters and memories buttons and it's OK again :? Frog Reference No 5511 - When transferring a memory, if you page up or down to select the submaster page - after the transfer is completed, the memories screen locks up. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Paul Posted February 25, 2005 Report Share Posted February 25, 2005 The problem isn't just limited to the transfer (with/without time) pop-up, if you change submaster page when other pop-ups are active (e.g. Frog Screen, Edit, Preview, even Frog Run), then the Memories Screen menu navigation appears to hang when the pop-up is cleared. The problem is also seen on the SX Screen on the Mambo Frog. Simply hitting the Memories or SX Screen button clears the problem. Quote Link to comment Share on other sites More sharing options...
