Brian M Posted June 18, 2006 Report Posted June 18, 2006 I have been reading about problems with upgrading by Floppy Disk. Is there any plans to upgrade to a Memory Stick feature? If so would there be any way to upgrade older machines to this new technology? I am using a Version 4 with a 9.1 upgrade. Just tried to upgrade to 10.4 but didnt work. I put the disk in and it did nothing but will keep trying. Cheers Brian Queensland Australia Quote
Hornett Posted November 15, 2006 Report Posted November 15, 2006 I think that if the option was available to have the Floppy Disk drive changed to a Memory Stick Module would be great for us. We all carry around data sticks with at all times. it would be good to know if the memory stick option would mean that you could still store other things on the dongle not just shows from the frog. Another great thing is the durabitlty of a memory stick they are so much stronger than a floppy disk and less likely to currupt, so al in all i think it would be a great option to have and i would say yes if that option was available. Quote
dogsbody Posted November 16, 2006 Report Posted November 16, 2006 Yes please to an usb socket at £100 or less, hope this is how you register a vote as I can't see any other way. Quote
dogcop Posted November 5, 2007 Report Posted November 5, 2007 hi there is there any update on USB retro fits on the frogs. We now own 2 of the desks in our church and there are few floppys now out there ?? Quote
Kirkup_xp Posted November 5, 2007 Report Posted November 5, 2007 As you can see we did consider this option but due to the cost of such an upgrade we decided instead to develop the Leap Frog 48 & 96 desks, which have a lot of new features on top of the usual Fat Frog mentality & feature set. The lower end of this market place has now been filled by the Jester ML, which also sports a USB port. Unfortunately this isn't an easy answer for you. Edit: the poll seems to have disappeared from this topic, not sure why... Quote Peter Kirkup
Brian M Posted April 11, 2009 Report Posted April 11, 2009 This is probabally the wrong place to ask this but here it is. Can a standard Frog be upgraded to take a USB port?myfloppy disk wont do anything anymore. It just says no disk I think it was. I am thinking is it better to just upgrade to the Jester 24/48. I must say the Frog is still performing well with no problems except the floppy. Thanks for any advice. regards Brian Quote
J. M. Thomas Posted November 25, 2009 Report Posted November 25, 2009 Hi, just curious about the 3.5 drive. Would a 3.5 inch SmartMedia adapter work in the Fat Frog? This is a "disk" that you plug a SmartMedia card in and then insert the disk into a floppy drive. I have used the Sony Memory stick to 3.5 adapter before in the old Mavica camera that used 3.5 disk to store the image. When I searched for one however, it was $$$$. I was about to find a SmartMedia adapter for less than 20 bucks American. Just curious, I am tempted to just stick it in the Frog but I dont want to do something that might damage the Frog. Thanks in advance. JM Quote
Paul Posted November 30, 2009 Report Posted November 30, 2009 That adapter isn't something we've ever tried, so we can't tell you whether it would work or not, sorry. A while ago, someone also asked us about THIS, but again, not something we've tried, so we can't say whether that would work either. If anyone has any experiences to share, good or bad, then please let us know! Quote
Webbo Posted January 3, 2013 Report Posted January 3, 2013 Started a new thread on this topic, then found this one. Has anybody tried to fit a Floppy to USB adaptor in the FROG? These are available on e-bay from £20 or so & are designed to replace the floppy in textile machinery. Supposed to be a simple plug n play installation. Quote
Jon Hole Posted January 7, 2013 Report Posted January 7, 2013 Hi Webbo, Several of our customers have had success using USB emulators (I can't confirm where these units came from) but this isn't something that we can directly support or be responsible for. Quote Jon Hole Global Product Manager, Systems and Control
NickTaylor Posted June 9, 2014 Report Posted June 9, 2014 I have now done this on two desks. As long as you format the usb stick on the desk all seems to work fineI Quote
