Hi folks...
From a recent gig I did with a Fat Frog I was never able to record a position chase which did not affect the colour of either Mac 300s or MiniMac Profiles.
I've been playing with the offline editor for a while now, and can't work it out. I've set partial recording mode, and can successfully record subs of
a) Intensity of mover
B) Two-step position chase
If I bring both up in any order, then apply a colour from a palette, it works fine.
I can then close the fader for the position chase, which stops the lamps in their tracks, retaining the paletted colour.
The problem arises when I raise the same fader again, expecting the position chase to start again and not affect other attributes. Instead, the colour reverts to open (or, I assume, whatever it was when the position chase was programmed.) The same happens for gobos, rotation etc.
Any wisdom? The answer is probably something really trivial, but my thanks to whoever has the patience to answer...
It sounds like the position chase also contains colour and probably beamshape data as well. If you only want to record the position parameters into the chase hold down the POSITION key and then press PROGRAM when programming the chase.
The memories screen should indicate which attributes are actually programmed in the chase; you can also check on the preview screen.
