funkytwig Posted March 10 Report Posted March 10 With our old Alcora desk, the Grand Master affects all fixtures that are set (if I have all faders to 0 except 1-3 the grand master affects only 1-3. With our FLS S24 Master Payback (which I think has been setup as Grand Master) changes the level of ALL fixtures, regardless if they set to 0 or 100% or anything in between. Is there a way to get the Master PLayback to behave like the Grand Master on the Alcora.  Quote
kgallen Posted March 10 Report Posted March 10 For the benefit of others I’ve been ‘helping’ Ben with this on the BlueRoom forum. However as yet we’re not ‘on the same page’. Maybe other users can help us see the light! For those who aren’t familiar with the Zero88 Alcora it’s a basic entry level non-tracking memory console with a single memory stack with a Master Fader and a Grand Master Fader (since you could mix memory levels with other ‘manual’ fader levels). There is nothing ‘quirky’ with the Alcora in this respect.  The BR thread is here: https://www.blue-room.org.uk/topic/79592-flx-s24-setting-grand-master-on-master-playback/#comment-616676  Thanks!  Mods: @DMH @RJP ideally this post would be moved to the FLX S24 forum. Quote
funkytwig Posted March 12 Author Report Posted March 12 LOL, I posted here as I thought UI was taking up too much of kgallens time and thought ide take another approach, will chack bak there. Quote
kgallen Posted March 12 Report Posted March 12 I said you'd probably get me here too! 😄 This would probably be a better place to continue the conversation otherwise we'll probably end up cluttering up the Blue Room forum with a level of chatter and detail many others there will get irritated with. Also on here you can post pictures/screenshots etc which you can't do directly on Blue Room.  Kevin Quote
