Lekengard Posted October 9, 2002 Report Posted October 9, 2002 How come if i select different type of fixtures shutter is not shutter for all types in beam bank????? :cry: Quote
K-Nine Posted October 9, 2002 Report Posted October 9, 2002 One of the main problems with different fixture profiles especially when they are from different manufacturers is that the same "functions" are often called different names, work in different ways and are on different DMX channels relative to the start address of the fixture. They therefore will appear on different wheels/wheel groups for different fixtures. One of the limitations of being able to select several fixtures of different types at the same time is that corresponding parameters on wheel groups may be different. See Frog Series Operating Manual - Issue 3 - Page 4-6 for details. Cheers, K-Nine. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Lekengard Posted October 9, 2002 Author Report Posted October 9, 2002 The two different types i used was Technobeam full & Technobeam Iris.... Cant you please make it work like the WH??? I think its just a way of naming things when you do the Pers. file. So shutter is shutter in all fixt....... Quote
Laubfrosch Posted October 10, 2002 Report Posted October 10, 2002 Hi Lekengard, there is already a Fixture editing Software in download area. (CLICK HERE). You may build your personal Library for your favourite fixtures and set same Attributes on the same wheel. :idea: Probably this solves your problem. :wink: cheers Sven Quote Sven Paulsen Klangfarbe Vienna
