Hi, just wondering if there is anyone here that uses wysiwyg and knows how to draw 3D. Im having troubles with designing the stage. Can I import from another CAD software ?
It's an easy venue, little. but it's triangular shaped
The easiest way is to import an existing CAD plan in AutoCAD format, and then 'extrude' the walls to become surfaces. These surfaces can then be grouped to become the venue. You won't get all the detail, but at least you'll have a workable 3D plan.
Peter Kirkup
