mike.e Posted December 5, 2004 Report Share Posted December 5, 2004 Using MAc500 for the first time. Why, when I set them up and then used a submaster did the MAc's go to rest? They undid everything I had set!!! Quote Link to comment Share on other sites More sharing options...
Pipo Posted December 6, 2004 Report Share Posted December 6, 2004 could you please explain how and what you've programmed on the sub. Quote Den Pipo Pro Light Design Link to comment Share on other sites More sharing options...
mike.e Posted December 6, 2004 Author Report Share Posted December 6, 2004 I am using the fat frog. I had prepared various states using conventional lanterns and had prepared a position for the MAC500's prior to putting into a memory. I wanted to mix these setting with a sub but when puting up the sub the MAC's went to "sleep"!! I have overcome the problem by using the sub first then positioning the MAC. My query was mainly for interest. Quote Link to comment Share on other sites More sharing options...
K-Nine Posted December 7, 2004 Report Share Posted December 7, 2004 Is the desk in full or partial mode ? If you are in full mode - all fixture parameters (brightness, colour, beamshape and position) will ALWAYS BE RECORDED AT THEIR CURRENT OUTPUT VALUES when you record a memory or submaster. If you wish to have fixture data on submasters it is probably better to have the desk in partial mode and only tag those fixtures that you require to change when you raise the submaster fader - see manual for further details Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
