Neil Macmillan Posted January 10 Report Posted January 10 I have some 16 bit capable fixtures which have channel 1 and 2 for intensity. I hoped to get some nicer smoother slow fade ups (at least to the capability of the fixture) by switching to 16 bit mode, but I don't seem to be getting a true 16 bit. So to follow, I bring the fader for the fixture to 100% then store to a playback. I then go into the setup for the playback, raise and lower tab then change the raise time to, for example, 255 seconds. When I watch the dmx output, I would expect to see the 1st channel stay at zero while the 2nd channel goes through 0-255 in 1 second, then the 2nd channel would reset to zero as the 1st channel increments to 1 and so continuing till in 255 seconds they both read 255 and 255. Instead, they increment as 0,0; 1,1; 2,2; 3,3; 4,4 and so on till 255,255 - in effect, only 8 bit duplicated over two channels as far as I can see. Am I missing something? I understand that the board only allows 0-100% control via the faders, in 1% increments, so it can never achieve even 8 bit control from a fader, but was hoping it may be able to automate it via raise time. For reference, I am on the latest version 8 firmware (build 8), running a FLX S24. Quote
kgallen Posted January 11 Report Posted January 11 Have you patched a fixture profile that has the intensity channels defined as 16-bit? i.e. the exact same correct 16-bit mode on the fixture and on the desk? Otherwise most fixtures have the intensity MSB as the "intensity" channel and you'll get 8-bit dimming as the "fine" LSB will just stay at 0. I think I might have the odd fixture with 16-bit intensity, maybe I could play sometime if I can find which one it is...! Quote
Neil Macmillan Posted 10 hours ago Author Report Posted 10 hours ago On 1/11/2025 at 12:59 PM, kgallen said: Have you patched a fixture profile that has the intensity channels defined as 16-bit? i.e. the exact same correct 16-bit mode on the fixture and on the desk? Otherwise most fixtures have the intensity MSB as the "intensity" channel and you'll get 8-bit dimming as the "fine" LSB will just stay at 0. I think I might have the odd fixture with 16-bit intensity, maybe I could play sometime if I can find which one it is...! Sorry for the slow reply! It's rising the two numbers simultaneously, so it is making some attempt at playing across the two channels. Just the two numbers duplicate each other. Perhaps the S24 is purely an 8 bit intensity setup and it just fakes being 16 bit to support the profiles. I do see on other channels, such as pan/tilt etc. it does use the full range. Something I'll need to try perhaps is to make a profile which has a 16 bit setting which isn't intensity (some other option such as a beam setting) and try to see if it is able to move those settings on a 16 bit fade. Just makes it a bit inconvenient that the fader wouldn't really do anything beyond selecting the light. Quote
kgallen Posted 10 hours ago Report Posted 10 hours ago 15 minutes ago, Neil Macmillan said: Perhaps the S24 is purely an 8 bit intensity setup and it just fakes being 16 bit to support the profiles. I doubt it (but I need to do the research to substantiate that, so will endeavour to find "my light")! Being able to define intensity as 16-bit has been in the "old" fixture editor from well before FLX series desks were designed and I doubt they would have not written the software to support that on their latest range of consoles. If it was just 8 bit it would just use the MSB channel and leave the LSB at 0. Needs some more investigation unless another user already knows the answer (you never know, Edward or Jon might answer as they are still lurking 😉 Quote
