Buonasera
Il lato destro della mia consolle FLXS24 non funziona più correttamente, è per poter lavorare devo agire tramite il touchscreen del tablet che ho collegato tramite l’app ZeROS Monitor
qualcuno può aiutarmi a capire cosa sia successo e se si può calibrare il touchscreen della FLXS24?
grazie
@Charlie Newman S24 doesn't have a DVI-D monitor port (only S48 and full FLX).
However I agree it's not clear what "right side" is, if the console is still otherwise full operable from the Monitor App.
@LIGHTING can you clarify please? Is the console fully working except for the internal touch screen? I understand internal touchscreen failures are uncomfortably common on S24. If yours has failed and it's still in warranty (up to 3 years old), then you need an urgent service request entering with your supplier. If the console is over 3 years old, then Zero88 might still help but I've also heard that the touchscreen is a standard component used with Raspberry Pi boards, but just with some extra mounting parts that could be transferred over. However I have no other knowledge or experience of this.
