Is there a way to show the currently active playbacks on the FLX S24? And/or a way to release all playbacks?
When programming I often bring up an existing playback(s), then switch to channel mode, make various changes and save it. By the time I'm done I've forgotten which playbacks I started with and end up having to take all the sliders up and down until I catch the right ones.
Thanks!
R
Hi Richy,
The MFF Window shows you which playbacks are active (excluding the Master Playback). In this screenshot, Playback 1, 3, 4, 5 & 6 are recorded, but only Playback 4 & 5 are active.
To release all Playbacks (excluding the Master Playback) hold down the CLEAR button and tap FADER FUNCTION (the Channels/Playbacks button).
  • Like 1
