RDM - Remote Device Management. Means you can assign the DMX address, change fixture settings, etc, all remotely. This report (on the Wybron website) explains RDM well.
ACN - Advanced Control Network. An alternative to DMX, which can run over ethernet cabling. Multiple universes down one cable. It works by assigning each fixture an IP address instead of a DMX address, and thus much larger systems can be built from one output on the desk. This report (from ALIA) lays out ACN quite well.
Peter Kirkup
