danilo1 Posted Tuesday at 12:48 PM Report Posted Tuesday at 12:48 PM bonjour je n'arrive pas a enregistrer des cue sur ma flx24 quand je fait RECORD le bouton GO ne clignote pas et si j'appuye dessus rien ne se passe... il doit y avoir une config du bouton GO désactivée mais lequel ? merci d'avance Quote
kgallen Posted Tuesday at 02:19 PM Report Posted Tuesday at 02:19 PM Is there anything to actually record? ie did you actually change an intensity or colour etc There is no record disable. If you press and hold RECORD is SmartTag enabled? Quote
danilo1 Posted yesterday at 12:52 PM Author Report Posted yesterday at 12:52 PM hello smart Tag ok je n'arrive toujours pas rentrer mes cue .... Quote
kgallen Posted 22 hours ago Report Posted 22 hours ago Ok good. clear-clear View GO Faders in channel mode Push up some channel faders - I assume you have some fixtures patched! Output window should show values RECORD GO does that work? Quote
