Phil Mckerracher Posted October 26, 2024 Report Posted October 26, 2024 I occasionally use a Leapfrog 48 desk at a small theatre in the UK, and it has recently (I think) gained the ability to disable "page handover" on "playbacks" (previously called "submasters"). It's a brilliant feature but it seems to have a fatal flaw - there's no quick way to clear them all. Or is there? I can't find any documentation about this. So that's my question - how can I quickly clear all the active playbacks, if they are scattered around the 20 available pages? For context, I use playbacks quite often to add effects to live music shows - things like spotlighting soloists, changing colours to follow the mood, pulsing for a disco effect, chases and so on. The problem is there are only 10 of them and I typically have more effects than that. There are 20 pages though so in theory 200 effects are available to me, but until now "page handover" meant only 10 could be actively in use at any one time. Then I discovered someone had disabled the page handover feature (I think) and now I can bring up multiple effects on any of the 20 pages. Fantastic! The only problem is, at the end of the song I faded to black using the master fader and tried to clear everything ready for the next scene by pulling down all 10 playbacks and pressing CLEAR a couple of times and it didn't work! I seem to be required to cycle through 20 pages of playbacks looking for the active ones and clear them individually. Meanwhile the audience is in the dark and getting restless. That's unacceptable and so the feature is useless. Surely there must be a way, though? I would have expected multiple CLEAR presses or perhaps SHIFT + CLEAR or something would do it, but I couldn't find a way (in the time available, I only have occasional access). Am I missing something? Quote Phil McKerracher www.mckerracher.net
kgallen Posted October 27, 2024 Report Posted October 27, 2024 Hi Phil Not sure what buttons you have on your console but CLEAR+Fader Function is how you do it on FLX. Probably you have equivalent buttons on your LeapFrog. https://www.zero88.com/manuals/zeros/cues-playbacks/playing-back-cues/triggering-releasing-playbacks 1 Quote
Phil Mckerracher Posted October 27, 2024 Author Report Posted October 27, 2024 That looks promising. Is "Fader Function" what I would call the "flash" button under each "submaster"? (Giving away my age here!). If it's a single button on the main console I don't think I have that. Quote Phil McKerracher www.mckerracher.net
kgallen Posted October 27, 2024 Report Posted October 27, 2024 Maybe the Memories button. For Solution console that’s what that manual page says. Quote
Phil Mckerracher Posted November 2, 2024 Author Report Posted November 2, 2024 Thanks, if I can get the simulation to work I'll try it. (Someone has just given me links to it in another thread.) Quote Phil McKerracher www.mckerracher.net
kgallen Posted November 2, 2024 Report Posted November 2, 2024 1 hour ago, Phil Mckerracher said: Thanks, if I can get the simulation to work I'll try it. (Someone has just given me links to it in another thread.) Yea, me! 😆 Quote
Phil Mckerracher Posted Wednesday at 09:40 PM Author Report Posted Wednesday at 09:40 PM Update: I finally got this to work in the simulation using Clear + Fader buttons. Still more than 10 button presses but a big improvement. So, many thanks for that tip. I'll have a chance to try it on the real board later this week. I think I've found a solution for my other question as well. Quote Phil McKerracher www.mckerracher.net
Phil Mckerracher Posted 22 hours ago Author Report Posted 22 hours ago Update: Tried this on the real board in the theatre and it didn't work. The board has been upgraded from a Leapfrog 48 to a Solution which might explain that. But what DID work was better - Clear + Submasters. This cleared them all in two button presses, which is great. Except when it doesn't. 😞 It's not reliable - some faders still sometimes had to be cleared manually by cycling through submaster pages, finding active submasters and raising and lowering the fader. It doesn't always happen and I didn't manage to find the crucial difference between the ones that clear and ones that don't in the time available. Quote Phil McKerracher www.mckerracher.net
