Select fixtures.
Make the colour however you want. You could start with an existing palette then modify with the encoder wheels.
Then RECORD and touch an empty palette location on the Colour screen.
Same process for position, beam, shape (but on those generally parameters are separate).
This is in the manual.
https://www.zero88.com/manuals/zeros/palettes/recording-palettes
@van den abbeele Eric can help you with a French manual.
  • Like 1
