jmd Posted September 24, 2024 Report Posted September 24, 2024 Bonjour, Je souhaite utiliser des pars led avec zoom, cependant a chaque enregistrement je vois le zoom se mettre en place. Quelle est la bonne méthode pour ne pas voir le zoom bouger ? Merci Quote
kgallen Posted September 24, 2024 Report Posted September 24, 2024 Hi. You need to be recording in Tracking mode and don't use Snapshot. If you have SmartTag enabled, then if you just adjust the parameters you want to change for a cue, then when you record, the console will only record the parameters you changed (see Tagging in the manual). Zoom will only be recorded if you changed Zoom when setting up the cue. Quote
jmd Posted September 24, 2024 Author Report Posted September 24, 2024 J'ai déjà fait cet manipulation, mais sa ne fonctionne pas . J'ai du oublier quelque chose Quote
kgallen Posted September 24, 2024 Report Posted September 24, 2024 The Zoom should only move if you changed it, regardless of recording style. If the zoom is moving when you haven't changed it then I would test one fixture in isolation, then see if others of the same make/model do the same in isolation. I have some budget fixtures with zoom and they don't move the zoom unless I programme a change. Quote
jmd Posted September 25, 2024 Author Report Posted September 25, 2024 J'enregistre de la manière suivante dans Master playback. Cue 1 par led avec zoom ouvert à fond. Cue 2 avec zoom au plus petit. Malheureusement, je vois le zoom se refermer et je ne le souhaite pas, il faudrait qu'il se place dans le noir. Merci 👍 Quote
kgallen Posted September 26, 2024 Report Posted September 26, 2024 When do you expect the zoom to close? There is no opportunity between Cue 1 and Cue 2 for the console to use move on dark to prepare your zoom to small for Cue 2. Hence when Cue 2 is run you see the zoom close live, because when else could it happen? If you had a cue stack that looked something like this: Cue 1 PAR#1 full and zoom open Cue 2 PAR#1 goes to dark and maybe other stuff happens Cue 3 PAR#1 full and zoom small Then after Cue 2 executes when PAR#1 has gone dark, the console can use move on dark to prepare the zoom at small for when Cue 3 is executed. When PAR#1 lights in Cue 3 then the zoom will already be at small, so you won't see the zoom move live. Quote
jmd Posted October 3, 2024 Author Report Posted October 3, 2024 Bonjour, Concernant le smartag ,faut il le laisser actif ou inactif quand je veux le déplacement dans le noir de mes projecteurs ? Merci Quote
kgallen Posted October 3, 2024 Report Posted October 3, 2024 Hi, Move on Dark is not directly related to the use of SmartTag, more what information is recorded in each cue. However SmartTag enabled can be useful to support Move on Dark when the console is in the Tracking enabled mode. When your programming becomes more advanced, you can disable SmartTag entirely or for certain Record operations. Move on Dark relies on lights not having an instruction in certain cues, when the console can perform the Move on Dark action. Quote
