I have seen mention over the years that the Eclipse came with a cigarette lighter built in, a story even mentioned by Rob Halliday in his classic gear column.
However, I've seen two in the flesh (one of which I commissioned), neither of which had one. Both were the larger frame variant rather the low profile FOH style. I don't recall it in product literature either.
My question is- Did Zero 88 ever fit or provide cigarette lighters on the Eclipse as an option? I've no doubt they existed out on the road but probably an aftermarket mod by hire companies. (Realistically they would need a separate transformer as I'm sure the PSU would not have the headroom for an extra ten Amps without impacting on the output stability).
(To younger Forum users without grey hair, once upon a time most cars had a cigar lighter gizmo on the dashboard or console, you pressed it down and it popped up again after a short while and when you pulled it out it exposed glowing coils you could use to set fire to the smoking article of your choice. The receptacle lives on as the 12V accessory socket).
I realise people who remember the 1980s products first-hand within Zero88 are probably in short supply as they will have moved on or retired. However hopefully there is a Company archive and a keen custodian who can research as they enjoy the history.
