Oliver_74 Posted August 27, 2024 Report Posted August 27, 2024 Hi, is it possible to type in the pan/tilt values? Otherwise it’s pretty hard/impossible to set the same values using the encoder wheels thank you 🙂 Quote
Edward Z88 Posted August 27, 2024 Report Posted August 27, 2024 1 hour ago, Oliver_74 said: Hi, is it possible to type in the pan/tilt values? Otherwise it’s pretty hard/impossible to set the same values using the encoder wheels thank you 🙂 You can set specific percentages. To do this, hold Z/Shift and tap the Pan or Tilt label on the touchscreen. Then tap the Z/Shift key, and use the onscreen number pad to type in @ 25 ENTER. This would then take Pan or Tilt to 25%. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted August 28, 2024 Report Posted August 28, 2024 @Edward Z88 Does this work on FLX too? (Shift key then keypad?). Thanks! Quote
Edward Z88 Posted August 28, 2024 Report Posted August 28, 2024 3 hours ago, kgallen said: @Edward Z88 Does this work on FLX too? (Shift key then keypad?). Thanks! https://www.zero88.com/manuals/zeros/controlling-fixtures/parameters#syntax 1 Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
