1 hour ago, Oliver_74 said:
is it possible to type in the pan/tilt values? Otherwise it’s pretty hard/impossible to set the same values using the encoder wheels
thank you 🙂
You can set specific percentages. To do this, hold Z/Shift and tap the Pan or Tilt label on the touchscreen. Then tap the Z/Shift key, and use the onscreen number pad to type in @ 25 ENTER. This would then take Pan or Tilt to 25%.
Product Specialist
Email Support
