kgallen Posted July 27 Report Share Posted July 27 FLX, tracking, 7.14 In have two adjacent cues, say 10 and 10.5, where I’ve split the build. Cue 10 lights the stage, cue 10.5 adds the front of house. How can I merge cue 10 and 10.5 into one cue without losing lighting data, as if I’d only recorded the one cue in the first place? I’d like to end up with cue 10 or cue 10.5 I don’t mind, and be able to delete the other now unused cue. Thanks! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted July 27 Report Share Posted July 27 To do this, you would need to copy/move cue 10.5 to an empty playback, and then play back this cue along with cue 10. You could then press UPDATE, ensure SmartTag is enabled, and press GO, to merge the data (On Orb, you could use LOAD syntax, to allow you to go into a cue and also load a cue into the programmer, to allow you to easily merge the data.) 1 Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
kgallen Posted July 27 Author Report Share Posted July 27 Thanks for very quick reply! 😍 1 Quote Link to comment Share on other sites More sharing options...
