kgallen Posted July 27, 2024 Report Posted July 27, 2024 FLX, tracking, 7.14 In have two adjacent cues, say 10 and 10.5, where I’ve split the build. Cue 10 lights the stage, cue 10.5 adds the front of house. How can I merge cue 10 and 10.5 into one cue without losing lighting data, as if I’d only recorded the one cue in the first place? I’d like to end up with cue 10 or cue 10.5 I don’t mind, and be able to delete the other now unused cue. Thanks! Quote
Edward Z88 Posted July 27, 2024 Report Posted July 27, 2024 To do this, you would need to copy/move cue 10.5 to an empty playback, and then play back this cue along with cue 10. You could then press UPDATE, ensure SmartTag is enabled, and press GO, to merge the data (On Orb, you could use LOAD syntax, to allow you to go into a cue and also load a cue into the programmer, to allow you to easily merge the data.) 1 Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted July 27, 2024 Author Report Posted July 27, 2024 Thanks for very quick reply! 😍 1 Quote
