SKLSKL Posted July 22, 2024 Report Posted July 22, 2024 Hi there, I've just got a PIXELpoint Batten and when I go to add the fixture there are 7 or 8 different ProLight Battens but not the pixelpoint. Is there one similar that I could use or does a new fixture need to be created for it? Many Thanks in advance. https://www.prolight.co.uk/product_manual/EQLED059_Manual.pdf
Edward Z88 Posted July 22, 2024 Report Posted July 22, 2024 Hi @SKLSKL 4 hours ago, SKLSKL said: I've just got a PIXELpoint Batten and when I go to add the fixture there are 7 or 8 different ProLight Battens but not the pixelpoint. Is there one similar that I could use or does a new fixture need to be created for it? I would recommend operating the Equinox PIXELpoint Battens in 120-channel mode. This will allow you to patch a "40-cell – 8-bit" RGB Multicell fixture, which can be found under the “Generic” manufacturer in Add Fixtures. If you cannot find these generic multicell fixtures on your console, I would recommend updating your console’s software. If you would like installation instructions, please let me know. Once you have patched this fixture, please watch the video below for more information on controlling multicell fixtures... Please let us know if you have any questions. Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
SKLSKL Posted July 22, 2024 Author Report Posted July 22, 2024 Many thanks Edward, will give it a try and let you know.
