Hello, on my FLX I will set a Max Level or Topset for the Itensity of only one art of Fixture.
In the manual they say, I can edit a single fixture or an group. It will not work :D
If I set the itensity of one fixture and select it. Then I press REC, HOME and then "Max Level".Now not only for this fixture is set the Max Level, ALL Fixtures are limitet...
What do I wrong?
Thanks for your help!
Hi @Speedy
Welcome to the forum.
To record custom Home, Default, or Max Level values, you will need to ensure that “SmartTag” is disabled in the record options.
If your custom Max Level values are not currently how you want them, first tap DELETE > HOME > Max Level.
Then double tap CLEAR, and set the fixtures you need to your desired maximum level. Then press and hold RECORD, and in the Record Options that open on the touchscreen, ensure SmartTag has a blue stripe, meaning disabled. If it has a red stripe, tap to disable. Then tap the HOME key, and then choose Max Level. Now only the lights you adjusted will be given a Max Level.
I hope this helps.
  • Like 1
Email Support
