I'm having a tidy up of my groups & effects libraries, trying to delete old ones & re-arrange the ones to keep.
The zeros manual uses syntax to effect these changes but I can't get my Solution to do the same. Having pressed copy-to, how do I get it into Group mode to pick source & target. (I'm sure I've done this before, but I see the last Solution manual says the Copy button is just for Cues).
Similarly, I want to delete multiple groups in one operation but same problem arises.
I know some keyboard shortcut work on Solution - is there a list of which ones?
Simon
Thanks kg (if I may be so familiar - been reading your helpful replies for a while).  Don't seem to work on my Solution.  If I press [Del] then G on the keyboard, I just have "Delete" on the syntax line. I've tried pressing [Group] on desk and on remote but... nothing.
There's a short list of keyboard shortcuts in the final Solution manual (> = thru; @;  etc) which work but the FLX ones don't seem to carry across.
S.
Ramblings of the insane...!
I've had a good ole dig around on this subject and I can't find much at all. Clearly looking in the wrong place. There is a minimal keyboard map in the 7.9.2 Solution manual but I've not found anything else. In a release note for 7.10 it talks about Copy-to and Move-to but that is FLX only.
Sorry, I'm drawing a bit of a blank - and not knowing Solution at all really isn't helping (I went from Fat Frog to FLX). If I come across anything before Edward posts, I'll offer up some more drivel.
Kevin
  • Thanks 1
Hi All,
Apologies for the confusion here. Group/palette syntax isn’t available on Solution consoles. Keys such as GROUP purely change the MFKs, and do not bring the function onto the command line.
You therefore cannot delete/copy/move multiple Groups or Effects in one operation.
Email Support
