Simonkbike Posted June 10, 2024 Report Posted June 10, 2024 I'm having a tidy up of my groups & effects libraries, trying to delete old ones & re-arrange the ones to keep. The zeros manual uses syntax to effect these changes but I can't get my Solution to do the same. Having pressed copy-to, how do I get it into Group mode to pick source & target. (I'm sure I've done this before, but I see the last Solution manual says the Copy button is just for Cues). Similarly, I want to delete multiple groups in one operation but same problem arises. I know some keyboard shortcut work on Solution - is there a list of which ones? Simon Quote
kgallen Posted June 11, 2024 Report Posted June 11, 2024 9 hours ago, Simonkbike said: I know some keyboard shortcut work on Solution - is there a list of which ones? These pages do specifically mention FLX, but as Solution runs "the same" ZerOS maybe worth giving them a try. Sorry if you already know about these! https://www.zero88.com/manuals/zeros/shortcuts/keyboard-shortcuts Quote
Simonkbike Posted June 11, 2024 Author Report Posted June 11, 2024 Thanks kg (if I may be so familiar - been reading your helpful replies for a while). Don't seem to work on my Solution. If I press [Del] then G on the keyboard, I just have "Delete" on the syntax line. I've tried pressing [Group] on desk and on remote but... nothing. There's a short list of keyboard shortcuts in the final Solution manual (> = thru; @; etc) which work but the FLX ones don't seem to carry across. S. Quote
kgallen Posted June 11, 2024 Report Posted June 11, 2024 2 hours ago, Simonkbike said: if I may be so familiar - been reading your helpful replies for a while Ramblings of the insane...! I've had a good ole dig around on this subject and I can't find much at all. Clearly looking in the wrong place. There is a minimal keyboard map in the 7.9.2 Solution manual but I've not found anything else. In a release note for 7.10 it talks about Copy-to and Move-to but that is FLX only. Sorry, I'm drawing a bit of a blank - and not knowing Solution at all really isn't helping (I went from Fat Frog to FLX). If I come across anything before Edward posts, I'll offer up some more drivel. Kevin 1 Quote
Edward Z88 Posted June 11, 2024 Report Posted June 11, 2024 Hi All, Apologies for the confusion here. Group/palette syntax isn’t available on Solution consoles. Keys such as GROUP purely change the MFKs, and do not bring the function onto the command line. You therefore cannot delete/copy/move multiple Groups or Effects in one operation. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Simonkbike Posted June 11, 2024 Author Report Posted June 11, 2024 Many thanks for the confirmation@Edward Z88. As I feared but half-expected I was probably mis- remembering some other operation. S. 1 Quote
