gress Posted November 17, 2004 Report Share Posted November 17, 2004 If I have a memory entry, how can I edit it to just adjust the brightness on one of the conventional lights? Example: on memory 12 say I have channel 1,2,3,4 at 50 and I want to make channel 3 35, how would I do that? Quote Link to comment Share on other sites More sharing options...
ice Posted November 17, 2004 Report Share Posted November 17, 2004 Select the channel and raise the value all with the navigation keys (after pressing edit of course). Or a quicker way; edit -> press the flash button of the channel you want to alter -> punch in 0-100 (in your case 35) on the numeric keypad of your keyboard. Quote > 500 posts, time for a new T-shirt? Link to comment Share on other sites More sharing options...
K-Nine Posted November 17, 2004 Report Share Posted November 17, 2004 Modifying Scene Memories - Frog Series Manual - Page 4-9 Having entered edit mode and selected the required channel there are three ways to edit the channel level. Hold down the corresponding channel flash button, move the fader through the current level - it will then control the channel level. Use the fader to set the new level. Use the + or - keys to edit the channel level. If you have an external leyboard attached enter the required level and then ENTER. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
