Last week I noticed something... there is a way of somewhat programming individual parameters!
For instance; when you program a shutter chase, it is possible to alter something in the beamshape menu, without affecting the chase. That way you can create a shutter chase, and manually add a gobo. I don't know if this was an already known fact, but it's kinda neat as a solution for individual parameter programming. The only thing is you'll have to "add" things with the wheels, of course when you press a pallet all info is lost and the chase stops (I think).
Oh well, it's not individual parameter programming, but it saves some work in some situations.
No, I mean running a chase on (for example) the shutter parameter and then changing the gobo. I thought, because you program the whole beamshape group; the gobo would reset on every step of the chase (since you programmed it!) but that's not true. When you program a chase, and only alter the shutter parameter; the gobowheel is left alone. That means when you execute the chase, you can change the gobo and It'll stay on that one.
now I got it :)
I usually work with more than one fixture, so it isn't easy to switch between them and scroll the wheel.
but it's a great idea when you work with one fixture.
I'm sure I'll try it on smaller show :wink:
It works for more fixtures too.
For instance; program a shutter chase:
FX1 strobes -> FX2 strobes -> FX3 strobes etc.
Select all fixtures and scroll in a gobo, it'll stay there for all fixtures until you restart the chase!
